I picked up a Fisher Futura 202 Receiver at a GS and when I turn it on I get a pop from the speakers. I've cleaned all the pots and switches and will be doing a recap but is there anything else I should be looking at to eliminate the pop.
sounds like you got DC on the outputs. try checking dc offset spec. thats the dc across the spkr trmnls at zero vol no input on aux. should be <=20mv, idealy zero.
your rcvr may have diff. spec.
When I powered it on both terminals had 13 volts on them and then gradually dropped down to .2 volts. Any suggestions? Also looking for the service manual.
