i am running a chassis 50 mono integrated amp at work, that originally came from a model 101 gramophone. the turntable (a garrard 121/D) ran fine through the amp as originally configured, using a ge vr2 mono cartridge and diamond stylus.
i am currently trying to finish off the rebuild of my rek-o-kut B12, with an sme 3012 tonearm. i've put in (temporarily) a stanton 681eee cartridge, and connected it to the amp with a home-made interconnect, tied into a stereo-to-mono mixdown cable. the s-t-m cable works fine from my ipod. the home-made interconnect shows continuity, as do the tone arm wires.
when i plug it all in, set the amp to the RIAA (or any other) phono curve, and put the needle on a record, it makes no sound. neither does gently running my fingerprint along the stylus. at any volume level.
i am thinking the cartridge/impedance matching is wrong, or the cartridge type is incorrect for the fisher to use. i don't know the language to say it, though. should a 681eee be able to be amplified through a late '50s fisher mono tube phonograph system's phono circuitry (that worked using a variable reluctance cartridge)?
i'll be asking a similar question over in turntables, just to get a handle on terminology and cartridge types (mc, mm, vr, etc.).
thanks.
thanks.
