Fisher RS-580 Reciever question
Discussion in 'Fisher' started by n0rman, Nov 14, 2017.
  1. n0rman
    n0rman New Member
    3
    Hi, I'm new here. Thanks for a great forum.
    A friend of mine is selling Sony SS-G5 speakers for cheap and I already have an old Fisher RS-580 reciever. Would this be a good match for a home gym stereo, or do the speakers need more power?
    Thanks
  2. larryderouin
    larryderouin You can be sure if it's Westinghouse??????? Subscriber
    20,453
    Glen Burnie Md.
    From info I've gotten off searches, the 580 is rated for 100w each channel. Plenty of power for the SS-G5 which are rated 80W max. Most listening is under 5-10w anyway so they should match up fairly nicely. Just don't crank the 580 to 11. It's one of SANYO/FISHER offerings from the late 80's early 90's IIRC.
  3. n0rman
    n0rman New Member
    3
    Interesting. Can I connect these speakers with loose speaker wire directly or do I need some kind of adapter? I can't find any pictures of the SS-G5 terminals.
    Pardon the beginner questions...
  4. larryderouin
    20,453
    Glen Burnie Md.
    You should be able to connect directly. Most speakers of that era either have screw connectors or spring clips, OR 5way connectors.
  5. n0rman
    n0rman New Member
    3
    Ok.. thanks for the help. I'm going to pick them up later today.
    By the way (I hope it's OK to use the same thread) would it make sense for me to pick up an external DAC or CD-player with USB input to play music from my computer? I currently use 3,5mm jack to RCA which probably isnt ideal for sound quality, but I'm uncertain there would be any significant improvement in sound quality with the other stereo components.
  6. larryderouin
    20,453
    Glen Burnie Md.
    I really don't know the answer to that one. Maybe one of the other guys might have an answer for you. I don't really see a problem with the current setup except for maybe an impedance mismatch. But as they are both S.S. there probably isn't a large mismatch. I'd expect a large mismatch between S.S. and tube.
