Fisher TA-500 12ax7 Tubes
Discussion in 'Fisher' started by jgannon, Aug 11, 2017.
  1. jgannon
    jgannon AK Subscriber Subscriber
    5,390
    NY, NY
    I just have a very basic question. The Fisher TA-500 mono receiver has three 12ax7 tubes. If I am facing it, and looking down at it, there are two 12ax7's right behind the front grill of the receiver, and then one in the back with the three power tubes.
    I'm thinking that out of the two in the front, one of the 12ax7's is for the phono pre-amp, and another one for the tone amp. But I don't know which one is for which (or if I am even correct about that). And then there is the third tube in the back. What would that one be for?
    Thanks in advance!
  2. larryderouin
    larryderouin You can be sure if it's Westinghouse??????? Subscriber
    20,770
    Glen Burnie Md.
    I don't have a FISHER Manual with the top layout so we'll use a SAMS' photofact.
    V8 (outer front) is the phono preamp.
    V9 (inner front) is the AF Amp
    V10(back next to output's) is split into the Driver and phase inverter.
  3. jgannon
    5,390
    NY, NY
    Thanks Larry. But what does the AF stand for? Is that audio frequency? Is that what is considered the tone amp?
  4. larryderouin
    20,770
    Glen Burnie Md.
    AF = AUDIO FREQUENCY
    RF= RADIO FREQUENCY
    Af Amps are generally referred to as any amplifier stage other than phono stage. V9 would be the tone control section, while V10 is the Driver/Phase Inverter.
  5. jgannon
    5,390
    NY, NY
    Ok, thanks Larry. And thanks for that SAMS pic.
