solidjackson
I'm having an odd channel problem in my Fisher 600. One side is a little on the weak side and constantly hisses, snaps, crackles, pops when the volume is turned up. It's little audible in on the other side too, but only when I turn it all the way up.
The balance was really off when I got it, but replacing the small german electrolytics on the 12DW7's seems to have cleared that up. There's still a bunch of the things still in the amplifier though. I don't see any burnt out resistors and I've cleaned/lubed all the switches pots and sockets. I'd figure if it was one of the big electrolytics it would be in both channels. I've switched around all the tubes, and that doesn't make any difference either.
I've isolated a problem, though. When I turn the balance over to one side, and turn the volume up, I can hear the bass potentiometer scrape away when I turn it... but only on the left channel! Would that cause the intermittent noise?
