Unit: 1969 FISHER 500TX.
SERVICE MANUAL: Sitting in my Lap.
PROBLEM: NONE with Unit. Making up a parts list and xref old #'s to new #'s. Having problem locating Main power amp transistors.
Schematic of AMP shows TR1038-5 and TR1039-5
Actual Transistors MOTOROLA 01059-7 and 02059-7. All cases are domed, and all match physically. Lettering is good (authentic) as far as I can tell. The Motorola M then the 01059-7# and 139 under that on all 4. Mounting is intact, screw heads unmolested, showing as original. They are Silicon, TO-3cased. I will be renewing the Mica insulators and grease.
I run this unit 18-20 hours a day and it never gets warm. I did idle adjustment and it's @ 15mv per spec. I checked all voltage readings on all boards per schematic and values gotten are all within +1v to -1/2v. Line voltage is 120-122 depending on time of day. Schematic readings based on line voltage of 120.
I ran all 4 numbers thru Onsemi, Fairchild Rohm.........NADA!!!
SK shows sk9136 and 9134 for 1038 and 1039 respectively.
nte shows 180 and 181 respectively.
NTE is LAST RESORT. Destroying unit to save it humiliation of having had NTE parts in it is choice before NTE parts.
I don't know how to xref using what ever the mumbo jumbo is that MTF, Echowars, Avionic and others use to come up with other #'s.
Can someone please help with some numbers I can use @ Mouser or Digikey if I need these in the forseeable future.
Thanks in Advance
Larry
Thanks in Advance
Larry
