audmod01
Super Member
I have a Fisher X-101-C coming from an on-line purchase. It will need extensive restoration, as a prior owner removed the volume control, balance control, mode switch and removed numerous audio cables internally etc. and used it as just an audio output amplifier. I intend to restore full functionality to the unit.
I have a replacement Fisher volume only control with loudness taps coming from a separate purchase. It has no on-off switch on it, but I can deal with that by using a separate switch on the back of the unit.
In adding the missing balance control, do any of you know whether the balance controls Fisher used was a linear taper control or an audio taper type?
For missing knobs I assume I will have to search various on-line sources until I find what I will need.
Any thoughts?
Joe
Any thoughts?
Joe
