Hi,
I'm in the process of rebuilding my Fisher X-100-2 for the second time (replacing the radial leads electrolytics with cans and also the mistracking volume pot).
Looking carefully at the schematic (page 8 on the linked pdf), I've noticed that the red-yellow and red wires coming from the power transformer are have their position reversed.
The R/Y is supposed to go at the junction of C4, SD1 and SD2 but is tied instead at the junction of C1 and C2A. The red wire is supposed to go there but it goes instead at the junction of C4, SD1 and SD2...
It looks it was this way when I acquired the amp as the R and R/Y wires are cut to the appropriate length to reach their actual positions.
R/Y reads 4 VAC at junction of C1 and C2A. Red reads 160 VAC right after SD2.
I also have the needed 390 VDC after SD2 BTW.
Are the locations of those leads that important or it doesn't matter?
Thanks in advance,
Patrice
Schematic: http://fisherx100a.files.wordpress.com/2008/11/fisherx100ax1003.pdf
Thanks in advance,
Patrice
