Fisher X-100B with JBL 4412 Speakers?
Discussion in 'Fisher' started by NaiveMelody, Jan 5, 2019.
  1. NaiveMelody
    NaiveMelody New Member
    23
    Hello, I have the opportunity to get some JBL 4412 speakers but I am worried that I won’t have enough juice to power them with my Fisher X-100B. It looks like the Fisher can push out 50/channel and the JBLs are rated up to 150 (see below for full specs). Any thoughts or info would be appreciated. It’s a great deal so I’d rather not pass them up if the speakers will work. Thanks again!
    • Type: 3 way, 3 driver loudspeaker system
      Frequency Response: 35Hz to 27kHz
      Power Handling: 150W
      Crossover Frequency: 800, 4500Hz
      Impedance: 8Ω
      Sensitivity: 90dB
      Bass: 1 x 300mm cone
      Midrange: 1 x 125mm cone
      Tweeter: 1 x 25mm pure titanium dome
      Finish: oiled walnut
      Dimensions: 362 x 597 x 286mm
      Weight: 27kg
      Year: 1987
  2. larryderouin
    22,014
    Glen Burnie Md.
    Actually the X100B is more like a 20-25Watt per Channel unit. Back then with the IHF ratings it was a TOTAL wattage of 2 channels. It should be able to push the 4412's to slightly uncomfortable levels but nothing that would blow out windows, crack the neighbors foundation or give the kid down the block bleeding ears from 100ft.
    NaiveMelody and UncleBingo like this.
  3. UncleBingo
    1,503
    Room size and your listening habits have at least as much to do with it as the specs in question. Probably great in a 12X16, but may get lost or sound weak in a 20X30 or open floor plan situation.
    NaiveMelody likes this.
  4. NaiveMelody
    23
    Thanks for the advice, I really appreciate it!
  5. Lo-Fidelity
    Lo-Fidelity AK Subscriber Subscriber
    1,079
    Houston
    If you want a lot of help, ask the question in the Lansing Legacy forum.
