Will jj el84 tubes work in an fisher x100-3 that calls for 7189 opt tubes?Thanks in advance.
CORYK Active Member Mar 4, 2011 #1 Will jj el84 tubes work in an fisher x100-3 that calls for 7189 opt tubes?Thanks in advance.
T tube-a-lou Addicted Member Mar 4, 2011 #2 they will but won't last that long, look a Sovtek EL 84M's or Russian 6P14P's I believe.
Sam Cogley Last of the Time Lords Subscriber Mar 4, 2011 #3 Look for the Soviet 6P14P-EV tubes. The standard 6P14P's ratings will be about the same as an EL84, you need the uprated EV tube to replace 7189s.
T tube-a-lou Addicted Member Mar 4, 2011 #4 Sam Cogley said: Look for the Soviet 6P14P-EV tubes. The standard 6P14P's ratings will be about the same as an EL84, you need the uprated EV tube to replace 7189s. Click to expand... Thanks for that info. tube
