asech
I have a Fisher X1000 that is not getting good stereo separation, when the contour is turned to the max, the right side is much lower than the left, I ran a test signal from the internet and the left side produces the right and left signal through it but nothing on the right side until I turn the contour closer to mono...or turn it up a lot
I just fiddled a little more with it and it seems to even out the right/left with the volume at 11 oclock and then favors the left side at higher volumes, using headphones....
all tubes check ok, thinking now it may be the volume control worn out.
any one know the specs for that control? is it 500K?
thanks in advance,
Andrew
thanks in advance,
Andrew
