Homer4beer
Well-Known Member
Hi all,
Following on from my other thread (http://audiokarma.org/forums/index....aps-on-marantz-1060-can-i-use-np-caps.770598/) I'm now going about fixing the right channel of the power amp.
It was going beautifully until the right channel got some pretty decent hum in it and a big volume increase.
I now need to have the balance at the 8:30 position to be in balance.
Hum starting to become quite annoying when listening at lower levels. Still present using headphones.
Ok it seems the pre amp is fine. It's something on the right power amp.
Next step is? (Pulling the power amp apart completely)?
where to begin. you'll need the service manual and the circuit diagram.
I would start with measuring voltages, once the hum/loudness starts
(based on an assumption that when cold, everything is normal) you
can compare the right channel to the left channel. and note
any differences you find with the values on the circuit diagram and
any notations in the service manual.
you can skip a lot if you can determine where the signal goes bad.
1. if the preamp section is mechanically connected to the power amp
side, then swap preamp output signals. if it stays in the right then
you can eliminate the preamp sections as the cause.
The music you hear after it is off is just coming from the main filter caps draining since it is a cap coupled amp. As was mentioned before, look at the back of the amp for the jumpers that connect the preamp to the amp. Swap the jumpers so that the left preamp is going to the right amp and right preamp is going to the left amp. If the problem switches the the other channel, then you know the issue is in the preamp. If the problem stays in the same channel as before, you can pretty confidently assume the issue is in that channels driver section.
Since the 1060 uses those little plastic jumpers if original, you may have to get some other RCA interconnects that are long/flexible enough to route the preamp to the opposite amp channels.
