Adinol
Member
Greetings,
This is my first post.
I just picked up a TASCAM 34, for $80, that needs repair. I was told it only needed a new belt, but I quickly noticed other things that also need fixing. This is my first Reel to Reel repair job and I'm hoping to get some advise from experienced members, letting me know what to expect if I tackle this.
I already read this thread http://audiokarma.org/forums/index.php?threads/tascam32-pinch-roller-diameter.651096/ on rebuilding a pinch roller for a TASCAM 32. My T 34 definitely needs a pinch roller... please have a look at this...
I wish to rebuild it myself on my own mini lathe, so I'm hoping someone could tell me the correct diameter and also what kid of rubber I should get, and possibly where to get it.
The other problem is that the capstan is not turning. I can't turn it by hand and when I press the PLAY button (after engaging the tension arms) the reels spin, but the capstan does not. And the pinch roller solenoid also does not get a pulse (so the pinch roller does not pinch).
I assume that I do need to change the drive belt and I found a source for it here http://www.daeinconline.com/parts.html
The vertical axis on the supply reel is bent, so I'll need to fix that. Any tips on how?
The PITCH CONTROL pot spins beyond the min/max points, but that's probably just a superficial problem.
I cleaned the heads and tape path just a bit and this is the current condition.
Also, so far I've only removed the top cover and here are some photos that show the condition.
I found the OPERATION/MAINTENANCE manual at manualslib.com for the TASCAM 34B. But I cannot find a good service manual, neither for the 34 nor 34B. So, any help with that would also be appreciated.
In closing, I wish to fix this deck for my 6 y/old kid to teach him how music is recorded. I just feel that nowadays kids don't really understand how some things work because they are growing up with touch screen phones that do everything without providing access to how things work. My kid has his own turn table and a TEAC A-4010S and just loves records and tapes.
Lastly, I appreciate any help/advise and in return I will post descriptions and images of whatever I do, which might help others in the future.
Thank you all in advance...
