Fixing up a Yamaha T-1
Discussion in 'Tuners' started by Drum, Jul 9, 2018.
  1. Drum
    Drum Active Member
    345
    I really like the performance of my t-80, but I wanted something with that analog glow, so I grabbed a T-1 that needed some work. Bonus is the green and black goes well with my Onkyo M504,
    I have replaced the bulbs and painted the tuning and signal strength indicators (came out well I thought), but the meters themselves have a few issues. The center tune is not centered. It is off to the right when the strength is highest (and station sounds best). The signal strength also jumps around a lot. Does anybody have experience in fixing these issues?
    Also the tuning dial is off a bit - can I just slide the tuning string to get the indicator in the right place, or is there a better method for this?
    Pic of the "center" point of the meter.
    avionic likes this.
  2. clinic-audio
    2,346
    France
    Hello Drum
    1) is your "FM TUNING" indicator is in the center when you switch the power off ?
    2) if yes , please put your "stations indicator" aligned with the 0 at the beginning of the dial scale, without any antenna connected to the T1, and see when you switch the power on , if the needle is in the center or not
  3. Drum
    Drum Active Member
    345
    No. When the power is off the indicator is to the right, though not quite as much as what the true center tune appears to be.
    Thanks,
  4. clinic-audio
    2,346
    France
    So , your trouble is a simple mechanical problem
    once you have the meter in hand, just adjust the zero position and put your meter back in your T1
  5. Drum
    Drum Active Member
    345
    OK - I can do that. Thanks.
    Does the signal strength generally jump around a lot on these? It seems to be constantly moving.
  6. RxDx
    RxDx Speaker collector Subscriber
    1,281
    Virginia, the colonies
    It's going to move some, even on local stations. Mine did, at least, but large variations might be a problem.
    BTW, loved my M504, at least until it blew up. Quite the amp.
  7. Drum
    Drum Active Member
    345
    It is mostly settled on the local stations moving from about 60 to 65 fairly gently. It jumps about twice that much on some of the weaker stations. Sounds like this is pretty normal, so I won't worry.
    What happened to the M504 - got me worried now.
  8. RxDx
    1,281
    Yeah, I think you're looking at a real time view of propagation. The T-1 is a
    very good tuner, very much overshadowed by its big brother the T-2, though.
    Lost a channel on the M504, and I had enough information to know I wouldn't
    be able to diagnose and fix it. So I let it go. But it was a thrift store orphan, and
    I didn't know its history.
  9. bennybee
    bennybee Active Member
    164
    Brussels
    The signal strength meter on my T2 does jump around a lot too on most stations. I think it has to do with multipath reception (bad reception due to a less than optimal position of my antenna).
  10. rcs16
    4,309
    Baldwin, Ontario, Canada
    Seems to be a standard technique that yamaha uses, which is to sum the IF signal level detector with some of the detected audio through a noise filter and feed it to the meter or threshold detector for led/lcd ckts.
