OP: Am I correct that you’re asking about acquiring new recordings, vs. ripping existing CDs?
What is the bit depth and sampling rate of recordings that you are considering buying?
If you want to acquire downloaded recordings that have better than CD quality, then buy high-quality hi-res (24bit/96kHz or 24bit/192kHz) FLAC downloads, and hi-res DSD downloads. For his-res discs, buy SACDs, Pure Audio Blu-ray, Blu-ray, and Ultra HD Blu-ray.
Unfortunately, sellers often charge a higher price for high-res recordings. What is your priority - high quality, or cheap price?
You need to be concerned with the provenance of recordings (i.e., the quality of the original recording), plus the format of the consumer deliverable. (Garbage-in / garbage-out.) My understanding is that there was an effort in the industry to address the issue of provenance of audio recordings, but I’ve not seen these classifications on recordings. (Nonetheless, the issue of provenance is important.)
Master Quality Recording: A coding system devised by electronics and music industry trade groups to describe the provenance of digital music files for consumers, retailers and recording industry professionals. The four Master Quality categories include:
MQ-A: From an analog master source
MQ-C: From a CD master source (44.1-kHz/16-bit content)
MQ-D: From a DSD/DSF master source (typically 2.8- or 5.6-MHz/ 1-bit content). (DSF is a type of DSD master file.)
MQ-P: From a PCM master source 48-kHz/20 bit or higher (typically 96/24 or 192/24 content)
There’s a wealth of high-quality modern recordings available in hi-res download and disc formats.
Moreover, there are new ways to enjoy music, including
multi-channel hi-res audio, and hi-res audio/
video (e.g., concert videos).
A useful reference for hi-res recordings is HRAudio.net – however this site does
not list all hi-res recordings. HDTracks is a popular download site, but not all of its downloads are hi-res.
Most modern recordings are made, and mastered, in hi-res (24bit/192kHz) digital PCM format, or hi-res DSD (single-bit) format. The issue is whether you buy the recording in this hi-res format, or if you buy a deliverable that has been “down sampled” into the 30+ year-old CD format (or some highly compressed format that is optimized for portability vs. audio quality). In a “lossy” format, the music has been compressed in such a way that part of the music content cannot be recovered – in other words the audio quality is irrevocably compromised.
Some vintage recordings have been re-mastered and delivered in a “hi-res” format, in some cases using the original analog master tapes. In some cases, the results are very good. In other cases the poor quality of the original recording is apparent. (Again, garbage-in / garbage-out - putting a poor-quality recording in a FLAC wrapper doesn’t improve its sound quality.)
Have you read these threads?
http://audiokarma.org/forums/index.php?threads/flac-sources.807116/#post-11310005"]FLAC sources?
http://audiokarma.org/forums/index.php?threads/where-do-i-start.805298/
