FM-antenna for Dual CR50
I've not seen a plug that matches, but you should be able to insert the wires themselves into the upper and lower holes. a 300ohm dipole (the standard one you see everywhere) will work just fine. Many companies tried to replace the ubiquitous screw terminals in an attempt to make connecting easier, 30 years later they're just an annoyance. Looks like someone did that in the past already.
The center hole is likely there to prevent you from plugging the am and fm antennas in the wrong ports.
