LPD
Super Member
I had posted on the Lansing Forum a question regarding the poor response Altec/JBL speakers have in the audiophile community. Here is one response I found amusing and enlightning...
Yeah, I agree with XXX - although I think a lot of it comes down to fashion. Fashion dictated by compromise. All speaker engineering is compromise that's been fairly well understood for awhile. Something along these lines:
It is possible to get a flat 30hz from a 6" driver if you don't mind a limited output level.
Extended bass can come from a small mini monitor if you don't care about efficiency or power compression.
Full range drivers are possible, just don't move your head.
You can make a speaker with a 360 degree sound field, too bad all instruments don't produce sound that way.
You can make a speaker flat on axis, too bad all instruments don't produce sound that way.
Speakers can bounce sound off your walls like in a concert hall, which will only sound real if you're room is a concert hall.
A speaker can sound like it has more bass than it does if you bump it up a bit before you roll it off.
A speaker can sound real detailed if you let the tweeter resonate in the top octave.
A speaker with no bass can sound balanced if you roll off the highs.
A speaker can sound extended at both ends if you suck out the midrange.
A speaker can have a lot of presence if you concentrate the midrange power response in a limited forward direction.
etc.....
All companies make these decisions. When I grew up we called it the East Coast sound or West Coast sound or English sound or whatever someone feels is marketable. Don't fool yourself into thinking any speaker is perfect. The wavefront and propagation pattern of all the instruments playing in a group is too complex to nail with one speaker. Best you can hope for is too hear what the producer heard when he laid it down. This is what I think makes the JBLs and Altecs so exciting to listen to.
My opinion..........
etc.....
