Formula For Output Capacitors
Discussion in 'DIY' started by Andrew Heck, Jul 11, 2018.
  1. Andrew Heck
    Andrew Heck AK Subscriber Subscriber
    259
    chattanooga, tennessee
    So, I’ve been trying to figure out the value of the output couplers on my Xiang Sheng DAC-01a and there are no schematics available anywhere and the ones that are installed are very difficult to read... Anyway, I ran across a formula based on the input impedance of the amp downstream from the DAC. It is, as I understand:
    C=1/2 (pi) (hertz at roll off) (input impedance)
    So if I have an amp with resistance of 30K ohms, and I want to roll off around 8 hertz, my output couplers should be 376,800 what? uf, nf, pf? Or is this even close to right?
  2. audiotemp
    audiotemp Well-Known Member
    591
    I think you want C = 1/( 2 pi f R ), which in not what you've calculated.
    Also, if f is in Hz and R is in Ohms, then C will be in Farads.
  3. Andrew Heck
    259
    Thanks. Yes, that makes more sense.
  4. triode17
    triode17 Super Member
    1,389
    I got 0.66 uF. Don't forget the "one divided by" part.
    Andrew Heck likes this.
  5. gadget73
    37,736
    Southern NJ
    Sounds right without doing the math.
  6. Andrew Heck
    259
    So, my amp has a frequency response to 9hrtz. I should be able to use a pair of .58uf film caps for output couplers on my DAC and maybe ditch the WIMAs in the bypass positions? If so, how much of the leads on the films is too much if I have to run them back under the caps to the original points for the electrolytics?
  7. Andrew Heck
    259
    BTW I'm very thankful for the responses and help.
  8. HypnoToad
    HypnoToad Ms Puss Puss Subscriber
    6,149
    Melbourne, Australia
