Found this at the Goodwill $99
Discussion in 'Tube Audio' started by bane.oh, Jul 10, 2018.
  1. bane.oh
    bane.oh Active Member
    120
    Anyone know about it? Should I grab it?
    Thanks!
  2. cartop
    cartop Super Member
    1,243
    Worcester Mass.
    I don't know anything about them but I love the look of those old radios. Does it work?
  3. century tek
    century tek Super Member
    3,779
    The Evergreen State
    A 1940's Zenith floor standing radio with short wave? I would grab it in a heartbeat, but that's just me. :thumbsup:
    I LIKE MUSIC likes this.
  4. onwardjames
    16,671
    Kentucky
    It's for a specific niche, but a classic. Your call.
  5. bane.oh
    120
    It powers on and makes noise when I turn the selector switch, but I can't get any stations.
    Could the amp be modified to be used as a separate amp?
  6. Dneprrider
    Dneprrider Active Member
    150
    Atlantic Canada
    First ask yourself what would you do with it? I have had several Zenith floostanding radios over the years. Things to consider: They take up space. They are heavy. The power supply capacitors at a minimium will need to be replaced. My 1939 Zenith had lots of crumbling rubber coated wiring inside, which needed tending too. This may need the same attention. It has AM and SW. There are not a lot of good SW stations available to listen to anymore. I am not sure about AM stations in your location. However you can get a quality AM broadcast unit and transmit audio of your choosing to the AM radio. It will not be hi-fi but good all the same. This is not a hi-fi unit, it is a tube radio so it is not advisable to try and turn this into a tube amplifier.
    OutlawSun and CopperWizard like this.
  7. Dneprrider
    150
    Atlantic Canada
    No it is a radio not an amplifier, and it is mono and it needs that Zenith speaker to work. You cannot simply connect it to your stereo 8 ohm speaker. The speaker voice coil is part of the output circuit and is subjected to a high voltage output that would make short work of your stereo speaker.
  8. bane.oh
    120
    So it actually works. The reception is crappy and it needs to be cleaned, but it seems to work. I was hoping it got FM, but since it doesn't, it's not worth much to me.
  9. analog addict
    analog addict Glory or Death!
    9,101
    Central NC - RDU
    Although invented in the 1930's, FM didn't really exist back when that was built...
  10. notdigital
    notdigital AK Subscriber Subscriber
    2,306
    NYNY
    I would just for the cool factor: look at that dial!! For a c-note, it would be a fun refurb project.
  11. gadget73
    38,109
    Southern NJ
    To get FM on these, you add a PiloTuner
    To be fair, they're not exactly the final word in FM performance but its better than nothing.
    bobabode, drtool and mashaffer like this.
  12. Big Harry
    Big Harry Active Member
    283
    Hawthorne, California
    If you like the radio and have a use for it, then buy it if the price seems right to you. The radio dates from 1936 so it shouldn't have rubber coated wire in it. The radio is not high fidelity as it only has 6 tubes in it and will only receive AM stations. The radio is a black dial Zenith which will increase the value of the radio, but in order to use it, it will need all new caps, most of the resistors replaced, the tubes tested and will need an alignment to get the radio to work properly and be somewhat reliable. I own a Zenith table top radio with the same chassis in it and did a restoration on it years ago and it works fine for what it is. The radio has a single 6F6 output tube in it which is good for about 3 watts output which is plenty to drive the original speaker, but not much else. If you decide to buy the radio and want to restore it, I have the service info for it and I would be glad to help you do a restoration on it.
  13. macyjrm
    macyjrm AK Subscriber Subscriber
    1,309
    Mississippi
    Black dial Zeniths of that era are sought after by collectors. At a minimum I would rescue that one from Goodwill and try to find a loving home for it. Looks like it would restore beautifully. Certainly you would be the only kid on your block to have one.
    maxhifi, bobabode and OutlawSun like this.
  14. gkargreen
    gkargreen Active Member
    483
    Fairfax, VA
    Yep, an old black-dial Zenith, nice vintage radio, worked on a number of them. Being six tubes its not the last word in performance, and I can see from the dial sag it needs new rubber mount washers and probably the rubber mounts on the tuning cap are shot as well. Too bad about the grill cloth, doesn't look original either. These Zenith consoles were quite collectable 20 years ago, but that market has left the building. It will take new ps caps and all new coupling caps at the very least, anything less than that are you are asking for a fire in your house. If you know how to work on them and want a cool piece of furniture, go for it. But from your questions, I am guessing you don't and it will cost at least a C-note from a local radio collector repair person, make sure they do an alignment after the work, then it will suck in the stations from the Caribbean, pretty cool!
    bobabode likes this.
  15. AlTinkster92
    AlTinkster92 AK Subscriber Subscriber
    3,353
    NC
    bobabode and WhiteSE like this.
  16. robert_kc
    robert_kc AK Subscriber Subscriber
    919
    Midwest USA
    Think of this radio as a piece of sculpture - i.e., a work of art. My standard advice for art: Don't buy it if you like it - buy it if you love it.
    No Money and bobabode like this.
