For over 50 years I have been performing experiments. Some were blase while others were very interesting and informative. I will attempt to keep the comments simple.
Four experiments have come to mind. The first is current while the second, third, and fourth are from the past.
1) In the first experiment, I have two 10 foot interconnects. One is an RCA and the other is my own DIY. Each IC is connected between the source (dragon fly) and preamplifier of 25k ohms input impedance (Z). The output Z of the DAC is
I am able to switch between the two ICs via the coined silver contact selector switch on the preamplifier. This eliminates the switches contacts as a possible problem. No sweat though.
The RCA IC measures 355pf average and my DIY measures 167pf average.
That is over a two to one ratio. Inductance is neglible when compared to the high preamplifier input Z. The higher capacitance of the RCA would normally cause the loss of highs. However, the low output Z of the source pretty much prevented such a loss.
Interestingly, the higher capacitance RCA IC had tighter bass and as such thinner midrange. The treble was the same, or very close. I was also able to thin the sound of my DIY ICs by simply changing materials in the IC terminations.
2) In the second experiment, I used a pair of speaker wires and altered the termination material/solder and needed to alter the xover to compensate. Clear difference in sound. Could the difference be altering the resistance by type of solder. Yes it could slightly, but maybe enough.
3) The third experiment was the comparison between all copper and silver coated copper ICs. I do not remember the capacitance of either cable. The silver coated ICs had a zing on the high end that the all coppers did not have. The high end exaggeration, however, did not follow through to the midrange. The FR was perceived as a non linear response, even though the capacitance had not changed.
4) I never really thought about ICs sounding different until I heard/read about perceived differences. So I conducted an experiment. I used two identical ICs, same capacitance/inductance, except one "A" was plugged (RCA plugs) between the source/Cd player and preamp "X" (25k input Z), while "B" ic was soldered between the source jack and preamplifier input "Y" jack. Thus I was able to switch (again silver contacts) between. Of course I could reverse the preamplifier inputs "X" and "Y". Contact resistance of the RCA plug was milliohms.
The lesson that I have learned and am reinforced with is that materials do matter in sonic quality. There are more that I do not recall, but I hope this will encourage you to experiment and update your system whenever you want.
Cheers
Pos
Cheers
Pos
