Frankenstein Pioneer SX 737
Discussion in 'Pioneer Audio' started by rossm, Oct 7, 2018.
  1. rossm
    rossm AK Subscriber Subscriber
    309
    Halloween is coming up so how about a Frankenstein project ? I hope to make one good unit from the 2, plus will still need to build a case.
    What’s the odds of finding 2 Pioneer SX 737’s at the dump ? I really felt sorry for the abused guys so I drug them home. Some folks might have passed but I like a challenge.
    Luckily both units passed the dim bulb test and the relay also clicked.
    What a trooper even in this state the lights are on and it wants to rock !!
    The bottom unit, the one labeled A was much cleaner inside so I decided to go with that chassis.
    Between the 2 I should have 1 set of nice knobs and switch’s
    So far the score is
    Receiver A
    had broken tuner string
    Bent function shaft
    Bent record selector shaft
    Bent power switch shaft
    Bad fm mute switch
    Bent power switch
    Receiver B
    Was filthy inside
    Was missing speaker terminals
    Bent volume shaft
    Receiver A is on the right
    I have the front off receiver B to harvest some switches.
    The front cleaned up pretty nice.
    This with be my 1st pioneer of this vintage so I will likely be back to ask questions
    Thanks for reading
  2. zebulon1
    5,055
    Las Vegas Nevada
    Looks like fun.
    merlynski likes this.
  3. Watthour
    Bent shafts can be repaired. I've done many.
    That face may also be repairable if handled with care. The glass/plastic is going to be the toughest part.
  4. zebulon1
    5,055
    Las Vegas Nevada
    I would try lexan for the replacement glass. The original glass is hard to find and trying to have a glass shop drill three holes in new glass is virtually impossible.
    UncleBingo likes this.
  5. tarior
    tarior Dirty pool, old man? Subscriber
    6,587
    Kelso, Washington
    I'd find a new glass shop.
    eiraved likes this.
  6. zebulon1
    5,055
    Las Vegas Nevada
    Give me the number of yours?
  7. tarior
    6,587
    Kelso, Washington
    Palmer's Glass, Kelso, WA
    360-423-2154
    UncleBingo and eiraved like this.
  8. zebulon1
    5,055
    Las Vegas Nevada
  9. rossm
    309
    The Hako made quick work of the parts harvest
  10. rossm
    309
    Selector switch installed, was pretty happy I didn’t melt any insulation
    3214ECAB-478C-4B4B-8048-CF59C7E5B697.jpeg 05E53C5D-7790-44B1-9431-2F76262303F5.jpeg
    Pics of damaged switches, you think they can be repaired?
    Crap, just placed a mouser order and now I need 4.7 uf audio caps for the tone section
    Haven’t looked at schematic yet, I am assuming only the yellow caps are audio ?
  11. Watthour
    Yes, those bent shafts can be straightened.
  12. EngineerNate
    3,485
    The orange caps are usually low leakage types. Are any bipolar?
  13. rossm
    309
    Thanks for the hint!
    Did some searching here and found they’re indeed low leakage caps and not bipolar, the neg leg is marked. Found a post by markthefixer where he recommends the kl series, which I had in stock.
    The old caps were way off spec almost double the 4.7uf. So I was able to recap and replace the transistors on the ctl amp board
    9A516889-A197-49B8-B50C-DB86E3411DCA.jpeg 730D144D-7D3C-411D-BC4C-0252BAD546E2.jpeg
  14. cuda440
    cuda440 AK Subscriber Subscriber
    229
    San Jose, CA
    I think you want to get those tantalum caps (C1, C2, C23, C24) out of there too.
  15. john stumpf
    john stumpf AK Subscriber Subscriber
    688
    philippines
    if your game to drill your own glass the chinese sell diamond drills cheap on ebay. if you have a drill press be more than happy to explain. the glass is 3mm thick dont toss the old one as with either lexan or glass it will be handy as a pattern. if its like a 939 theres a plastic bushing in the push button holes. it halves for removal its got some rubber glue holding it together. soak the bushed end in lacquer thinner for an hour or so it WONT eat the bushings but will soften the glue
  16. Ricktptman
    Ricktptman Great Music deserves Great Gear and Vice-Versa. Subscriber
    517
    Where it's at!
    Yeah, Good glass cutters are hard to find these days. When I was young (and day gigs harder to find) I worked in a Hardware store and learned to cut glass. Cutting holes in it can be done, but like restoring this stuff, it's an acquired skill. But they're out there. Just not easily found at a Home Despot or Lowe's.
  17. john stumpf
    688
    philippines
    "glass hole drills" on ebay a 15 piece set for 9 bucks and 1 $ shipping and they work really well. im sure there are higher quality available but how many holes do we need to drill in GLASS???
  18. cuda440
    229
    San Jose, CA
    I got some diamond drill bits (more like a small hole saw) from Amazon and used my drill press. I watched some YT videos to see how it was done. I was able to start the hole okay, but it chipped out when it came through and I had the glass clamped tightly against a piece of wood. I tried starting the hole on one side and flipping the glass over to finish, but it chipped out even worse when the drill broke through. And I went slooooow.
    Did I use the wrong kind of bit?
  19. john stumpf
    688
    philippines
    i had the same problem on a 939 glass. but all i had was a hand held drill. i chalked it up to a "no drill press" issue but that set used a plastic insert behind the knob and the ragged edge was covered by it.it very well could also be an issue with rpm as well as feed pressure or even a combination.. in your case it might be worth while to see if the bit runs true to the press table...just a thought mind you. if i had a lot of them to do and a drill press i might be tempted to experiment a bit.the cut glasses here were only 25 piso's each @ 50 cents.i bought 5.the first one i broke the next four were reasonable and i used the best one.since then i made one for a qx949 and that was EASY.the three hole configuration was the most difficult. but if it was easy i guess everyone would be doing it!.... and whats the fun in that?
  20. rossm
    309
    Hi cuda440,
    Are you referring to the blue caps ? Good catch, I think they are electrolytic, they have + side marked
    Need to update my order
    Thanks
