Free Advent project.
Discussion in 'Speakers' started by teal'c, Apr 21, 2018.
  1. teal'c
    teal'c Moomber Subscriber
    18,488
    Michigan, N of Detroit
    I'm still not done with my first speaker project, but that's OK.
    Screenshot from 2018-04-21 22-43-02.png Screenshot from 2018-04-21 22-43-22.png Screenshot from 2018-04-21 22-44-32.png Screenshot from 2018-04-21 22-43-58.png
    Almost didn't go since the ad was an hour old, glad I did.
    Are there supposed to be positive/negative stickers at the speaker terminals?
  2. bobins08
    bobins08 Loving the dream Subscriber
    6,508
    St. Louis, MO
    The 8 ohm terminal is the positive, 0 is the negative.
    teal'c likes this.
  3. electronjohn
    electronjohn Plug it in & see!! Subscriber
    20,342
    minnesota
    Free=:)
    teal'c likes this.
  4. drumbum
    drumbum Super Member
    1,408
    Doug G. and teal'c like this.
  5. GD70
    GD70 AK Subscriber Subscriber
    14,594
    Northern Westchester Co, NY
    My favorite looking Advents.
    Won't take much to make them look new and sound great.
    teal'c likes this.
  6. teal'c
    18,488
    Since I'm getting ready to order foams I opened these up, and they're filled with block foam.
    Are they supposed to be?
    Sure takes up a lot of air space.
    These three were stacked behind the woofer, and there are two more behind the tweeter.
    Single cap. Checked the tweeters through the back connections and both worked.
    Weird things going on with the grills. One chewed upon by something and the other with a weird cut out.
  7. E-Stat
    7,174
    Most certainly. Acoustic suspension speakers like these along with their forebearers from Acoustic Research, KLH, etc. all required that for the design to work properly.
    teal'c likes this.
  8. teal'c
    18,488
    Seems weird, could have much smaller cabinets instead.
  9. E-Stat
    7,174
    There was an Advent model in a smaller cabinet. The compromise for similar response was lower sensitivity.
    teal'c likes this.
  10. jberger
    jberger AK Subscriber Subscriber
    2,170
    Long Beach, CA
    The grille cutout almost looks like it was made to allow the grille to be inverted and still fit around the tweeter (stackable Advents?).
  11. E-Stat
    7,174
    Not stock.
  12. jberger
    2,170
    Long Beach, CA
    Definitely not stock.
  13. wmgwizard
    wmgwizard Super Member
    3,273
    Browns Mills NJ
    The foam inside actually slows down the back wave of the speaker tricking it into behaving as if it were in a LARGER cabinet.
    If they used a cabinet sufficiently sized for the woofer it would be too large for most potential buyers. The foam allows for a smaller, more marketable cabinet size.
    There is no Red/Black or +/- designation for the speaker terminals. IIRC the 0 is negative. Many people modify these by replacing the existing connections with color coded binding posts.
    teal'c likes this.
  14. toxcrusadr
    toxcrusadr Omelette au Fromage Subscriber
    33,965
    Central Missouri
    + and - only matters if you're a believer in 'absolute polarity'. <backs away from open can of worms>
    But I would have guessed 0 was negative anyway.
  15. KingBubba
    10,162
    Brooksville, Fl.
    As long as you are the same on both cabinet, you can wire them either way.
  16. E-Stat
    7,174
    Correct.
  17. quiet
    quiet AK Subscriber Subscriber
    2,576
    arkansas
    Foam blocks after 74. Fiberglass prior to that.
    GD70 and teal'c like this.
  18. Doug G.
    Doug G. Addicted Member
    7,287
    Rochester, Minnesota
    The grille frame is a stock frame. It's just been modified, probably for the reason jberger stated.
    Also read up on why acoustic suspension systems are filled with fiberglass or foam. It IS to make the cabinet seem larger to the woofer, thus extending low frequency response.
    Doug
    teal'c likes this.
  19. teal'c
    18,488
    I am familiar. However, it was my understanding that you wanted to reduce air movement while keeping as much volume as possible. That was why you "fill" with poly-fil, not pack tight with poly-fil. With the solid foam it seems you're reducing a lot of the volume that you want to keep. This setup seems like trying to put in a non-designed baffle system by just tossing in wood chunks.
    Wouldn't foam pieces like this be better?
    15 PPI open cell foam
    You don't loose as much air space while still drastically reducing the air movement resulting in an even "larger" volume cab.
    Looking around, it appears this type of foam wasn't invented until the 80's so they couldn't have used it.
    Any thoughts on it as an upgrade?
  20. SpruceMoose
    SpruceMoose Super Member
    1,687
    IIRC, five pieces of foam, 2” thick x 12” x 12”. Works great. Still using the foam in my home-built double advents. All drivers from 1977/78.
