In other words the AC position is a high pass filter allowing the higher frequencies to pass while preventing the lower frequencies from entering the amplifier circuits.
Why not just call it a low pass/high pass or a rumble filter or a low filter???
Other Yamaha equipment has it clearly labeled as in my C-50 preamps as a "sub sonic /15hz" filter.
Hi,
I have a Yamaha M4 amp powering a pair of Linn SARAS. There is a vertical slide switch on the back side that says "Mode AC or DC" and I'm not sure of the function. Can anyone help with it's function as to how it effects the music etc?
Regards,
klxdrt
Well, I wouldn't exactly call it a "high pass filter". After all, it's only a cap.
Your C-50 might actually have a 1st or 2nd order filter. I wouldn't know unless I looked at the circuit.
One thing that I just thought about is that cap might be a very good idea for those that use tube pre-amps. Tube amps have such high voltages that when warming up could expose the power amp to a significant voltage surge. If I had a tube pre-amp, I'd select the AC position.
Regards,
Jerry
