drspiff
Fisher "T" Aficionado
When recapping and replacing the large power caps, be careful grasshopper...
Attached is an illustration of a typical power supply found in old receivers. Notice the 2 capacitors after the full wave bridge. Also notice that the negative output of the supply is more negative than ground.
At first blush, the illustration looks symmetrical about the ground point. This might lead you to put your bright shiny new caps in back to back. Avoid this rush to finish. Let's say you put your caps back to back and tie the negative terminal to ground for each cap. Everybody knows that ground is negative, right?
If you do this, one of your caps will be in backwards. If you do not know what happens when a large electrolytic is reversed, suffice it to say, good for you. It is not a pretty sight. Even if the cap does not blow up, it is still ruined. Yep, You now have to buy another cap to replace the "bulgis vulgaris"
I know, it is a sad thing when a good cap goes bad. I always blame it on bad companions. Let this be a lesson to you grasshopper...
