G-9000 Upgraded Speaker Terminals Project
Discussion in 'Exclusively Sansui' started by MAXZ28, Jun 4, 2011.
  1. MAXZ28
    MAXZ28 Addicted Member
    6,520
    Springfield, MO
    Here's a practical project I felt other Big G owners would benefit from. :yes:
    I decided I've had enough finaggling with my busted up speaker terminals on my G-9000 and ordered some beefy upgrades. The challenge was how I was going to mount them and whether or not I was going to fabricate a new terminal plate. What I decided to do was use the existing plates and modify them to fit the new terminals.
    Here's what I started with...
    I pulled them off the chassis and removed the spring tension terminals with a needle nose pliers.
    I then drilled the 1/4" mounting holes in the center of the original openings using my drill press.
    Once the holes were drilled, I ground down the terminal frames flush with my belt sander and followed up with some fine grit sandpaper on my hand block.
    Mounted the new terminals and wired them in.
    Looks great and no more broken originals to fart around with. :banana:
  2. bassnutt
    bassnutt Well-Known Member
    872
    RIP 2016
    Great job :yes: that will work with th AU models also I have seen plenty of those broken.:D
  3. MAXZ28
    6,520
    Springfield, MO
    That's right - come to think of it, some of the G-x700 series receivers use the same terminal blocks also.
  4. Sir.Byrd
    Sir.Byrd Lunatic Member
    15,254
    Seattle, WA
    Beautifully simple solution, almost no waste as well!
  5. scottrt
    scottrt Well-Known Member
    622
    SF Bay Area, San Ramon
    Brilliant.... Elegant.
    Can you share a pic of the backside showing the nut and stem of the terminals, and a brand or model of the terminals?
    Thanks
    Scott T
  6. MAXZ28
    6,520
    Springfield, MO
    I've already buttoned up the G-9000 but I have a set to do for my G-801 so I'll snap a picture of the backsides and post it here once they're done.
    I bought them off Ebay....type in Speaker Cable Terminals Copper Binding Post Jack Gold and you'll find them. Didn't take long for them to arrive from HK.
  7. Oerets
    Oerets AK Subscriber Subscriber
    10,693
    Derby City U.S.A.
    Nice work !
    I will remember this for my G-8000 when it starts acting up .
    Barney
  8. a_retent
    a_retent Daddy's little shadow Subscriber
    687
    St. Paul, MN
    Nice work Darren!
    Jeez I hate them damned spring loaded thingys. I got them on the back of my Carver M400 and would like to get rid of them.
    Thanks to you I have another project. :D
  9. Robisme
    11,847
    Martinez California
    Very nice. Great idea and execution.
    Rob
  10. nosirrah
    nosirrah Moderator Staff Member Moderator Subscriber
    7,469
    30 min north of seattle
    Well done Sir!:thmbsp:
  11. kevzep
    That is awesome, I want to do mine now........:thmbsp:
  12. w1jim
    w1jim I can fix it but good... Subscriber
    7,715
    Boston western 'burbs
    Very nice / clean upgrade.
    The only thing I don't like about my big Sansuis is the side mount RCA and speaker connections. They make an already wide receiver all that much wider (and messier). The addition of binding posts like these are cool but if I choose to use banana plugs it adds another inch and a half.
    But they do sound awfully nice so I shouldn't bitch about the idiosyncrasies.
  13. MAXZ28
    6,520
    Springfield, MO
    I hear you, w1jim - there are a variety of speaker terminals much smaller dimensionally one could use to help minimize the "wideness" effect but I wanted the heavy duty insulated type. I have plenty of side space on top of my Expedit 2X4 If this unit would be going in a cabinet, I probably would have gone considerably smaller. :thmbsp:
  14. Satanzklown
    Satanzklown Member
    69
    florida
    Nice room setup MAXZ28 , very clean and comfortable looking , and your idea is great as I just received a BA2000 that uses the same terminals and just about bought a g9000 speaker plate off ebay at almost 70.00 .... your idea is much better and cheaper :)
  15. SPL db
    SPL db It's all about the music! Subscriber
    17,780
    Omaha, NE
    Do I spy...
    The Carver CD player that I traded to you for the speakers with the Pearless drivers? :scratch2:
  16. shelby1420
    shelby1420 Enjoying the music.....
    4,302
    Oromocto, NB
    Brilliant idea, looks awesome!!!
  17. Hyperion
    49,210
    Hertfordshire, UK
    +1 That is very clever use of the existing mountings to achieve a great end result. :thmbsp:
  18. DCinDC
    DCinDC I'm here to fix it
    4,401
    Northern VA
    That IS an elegant solution. Hat tip to you!
    < I admit I actually like the springy terminals but when they break ya gotta do something!>
  19. MAXZ28
    6,520
    Springfield, MO
    'Glad to have been able to help. :thmbsp: I think you can still get the 8 speaker terminals for under $19 shipped. I just did up two more sets of terminals for my other Big G's last week. I just have to get around to installing them.
    Sadly no. This is a DTL-200 MKII I ended up buying off the bay cheap. Just needed some new belts. I think that DTL-100 is still at Jays - I never made it up to Twangfest to collect it. :tears:
  20. Overundr1
    2,514
    Mississippi
    What a great listening space.
    -Lee
