Halisson
Member
Hello and thanks for reading.
I have read all posts about G6700 display faults, etc.
Mine is cut, lights do not turn on the center TUNE, but turns the TUNE on the left when identifying a poorly tuned radio.
I have a 50mhz oscilloscope, I can not detect any variation from the front end FF-631U, C16, C4 or before R8, the components test basic quickly look good.
I do not have any type of change in the cut numbers of the display, I do not have cold solder in the IC, I have no pre-scaler reading, 2SK61 on gate 11,6vdc.
could it be because my oscilloscope can not read> 50mhz, with grounding in the chassis frame or variable block?
Changing of the Crystal 6,553 mhz without change, I receive changes of the CI H11225 when monitoring on the oscilloscope on tune, etc.
Should I order the IC? The cost of shipping + purchase would leave 4x the initial value than advertised on ebay, I am afraid of not solving.
When switching to AM or FM, the numbers remain the same, FM only FM and MHZ light up, when switching to AM, turn on FM / AM / MHZ / KHZ light up, see photos.
I have the voltage f3060 of TR602 EMITTER 13VDC AND TR601 TRANSMITTER 5VDC and ground is OK.
Thank you
Thank you
