Gain specs for MC250 and MC225
Discussion in 'McIntosh Audio' started by Big Mac, Mar 14, 2018.
  1. Big Mac
    Big Mac Well-Known Member
    767
    Does anyone have the gain specs for the MC250 and the MC225.....with the gain pots turned all the way up?
    Thanks!
    BassKulcha likes this.
  2. Pio1980
    Pio1980 AK Member Subscriber
    25,570
    Angel Station, Alabama
    MC250: 0.50V for full output.
    MC225: 0.50V for full output
    Max sensitivity, adjustable.
  3. whoaru99
    whoaru99 Epic Member
    40,947
    LoTL
    Bear in mind they may have the same input sensitivity for rated output, but one is rated twice as much power as the other so the gains will be different.
    So, going with the 0.5V given above, the MC225 should be about 29dB gain wide open while the MC250 should be about 32dB gain wide open.
    Pio1980 likes this.
  4. Big Mac
    767
    Thanks for the info!
    How would I calculate the gain specs for, let's say, the MC2100 or MC2125?
  5. whoaru99
    40,947
    LoTL
    Find the voltage at the rated power and load then factor that against the input sensitivity for rated power at that load.
    For example I'll use the MC250.
    Rated power @ 8 ohms is 50 watts. 50 watts @ 8 ohms means 20 volts.
    Input sensitivity for rated output is 0.5 volt.
    dB (voltage) gain = 20log(20/0.5) = 32dB.
