birchoak
Hi-Fi Nut
I have read EchoWars's "So You Want To Repair Audio Gear?" and it is generous expert advice. After I read it, I wondered if there some sort of guide to basic troubleshooting of late 60's to early 80's solid state audio gear, mainly receivers and amps?
For example, when there's a low level, background hum or buzz from a receiver at 0 volume, does that usually indicate aged filter capacitors, barring bad equipment set-up, loose connections, etc.? What is usually is the cause of one channel completely gone in a stereo receiver or amplifier, beyond the obvious: balance knob dirty or turned all the way to right or left, volume pot dirty, other switches needing cleaning, blown fuse, RCA jumper(s) missing?
Allow me to go on: What seem to be the most vulnerable, failure-prone parts of most receivers/amps, in general? Things that see a lot of heat? Things with more than 2 moving parts in them, like relays and on/off switches? Electrolytic caps? The solder joints?
What components rarely fail in solid state electronics? For example, it seems like your average resistor, unless it has scorch marks on it or it's cracked apart, will last longer than anyone over 50 has to be concerned about. Output transistors mounted on big heat sinks seem fairly reliable to me unless the amp has been continuously overdriven or overheated through improper ventilation.
I'm looking for general information that would aid the everyman (not someone who's already an expert at this stuff) in at least troubleshooting common problems in amps and receivers. If that information can be relayed in simple terms that someone without a degree in higher electronics can understand, even better. This information would help people diagnose distorted bass on a Marantz 2230, for example, not how to re-wire the tonearm on a VPI Scoutmaster.
I know that I'm asking for a lot here, something that might not exist: a distillation of thousands of audio maladies into a simple "When this problem comes up, it's most likely this" solution, but it's worth a try. My personal goal is to save as many of these audio gems from the dumpster as possible. They are exquisitely crafted time machines, from an age that will never be repeated.
