Gloves for extreme cold?
Discussion in 'Sports & Outdoor Adventure' started by jcamero, Feb 4, 2018.
  1. jcamero
    jcamero Who are you people anyway? Subscriber
    4,245
    The Dairy State
    I cannot seem to find a really good set of durable gloves that actually keep the tips of my fingers warm. They would need to be durable for snow removal. I thought about heated motorcycle gloves, but would like other options too.
  2. Poinzy
    Poinzy Super Member
    2,008
    SE Michigan
    The really effective "gloves" are the ones that don't separate your fingers, aka mittens.
    turnitdown, unfairlane and MarZutra like this.
  3. dr*audio
    18,907
    Cleveland, Ohio
    LL Bean sells the warmest gloves I've found.
  4. swamppirate
    swamppirate Lunatic Member
    11,027
    Sweet Virginia Breeze
    Mittens with a heater pack inserted.
  5. squirrelnest
    squirrelnest Addicted Member
    7,452
    Alexandria, VA
    Go to a Ski shop....you'll find what you need.
  6. Chip Chester
    Chip Chester Super Member
    2,013
    Central Ohio
    They make battery-powered glove liners that keep you warm and fit inside whatever outer glove is appropriate for the task 'at hand' so to speak. Using these inside well-insulated waterproof gloves should work well. Although they may be so warm your hands sweat, which will make taking them off outside (for fine work) less than pleasant.
    Here's one source: https://www.primrose.co/deluxe-batt...-heat-packs-warmawear-p-35934.html?cPath=3213
  7. onepixel
    onepixel .
    35,250
    Maui
  8. SoCal Sam
    SoCal Sam Lunatic Member
    19,302
    Picker's Paradise
    It get's cold outside? 85d in So Cal today.
  9. slow_jazz
    slow_jazz AK Subscriber Subscriber
    13,889
    SE Michigan, Downriver....
    I've had a pair of Zero mittens for years.
    Purchased them with first snowmobile.
  10. blhagstrom
    12,902
    Duvall, Washington
    In ND, the extream cold answer is heavy leather fur lined mittens.
    Lots and lots of body fat helps too.
    Most recipies start with 2 cups of sugar, a pound of butter and ...
  11. Danddd
    Danddd AK Subscriber Subscriber
    942
    Wheaton, IL
    Using a snowblower, I find the vibration and metal handle bar makes it difficult for the fingers with the warmest gloves I have. And the gloves I use are Mountain Hard Wear heavy wool lined leather gloves which seem good enough in single digits to take the dog for an extended walk. Next thing I am going to try is see if a pipe insulator sleeve over the snowblower handle might help.
  12. Tjetracer
    Tjetracer Dancing Madly Backwards in PA Subscriber
    746
    I've gotten several pairs of gloves from Duluth Trading Company. Very good quality and very warm. Check out the sale items.
    https://www.duluthtrading.com/
  13. WillVT
    WillVT Super Member
    1,169
    Burlington, VT
    "Hot Hands" hand warmers are pretty great, and fairly cheap. There's nothing like having a nice little heat producing pillow in your gloves. As someone with perpetually cold hands, they really do the trick.
  14. robgmn
    robgmn Super Member
    4,533
    Twin Ports, MN
  15. dcreek
    dcreek Active Member
    132
    Vancouver Island
    'Extreme Cold" will mean different things to different people...
    I've worked construction in NWT (-45°) and ski guided/ patrolled in milder climates.
    For a lot of those circumstances I settled on full leather welding gloves with fleece gloves as separate liners. The outer gloves take all the abuse you can throw at them, and the liners are easily dried and/or replaced.
    Dirt cheap too. (Converted many coworkers after they had their Patagonia /North Face gloves stolen while attending to injured skiers - yes, some people go that low...)
    WillVT likes this.
