I finally had enough of the foolishness of retrofitting NuTone systems and - gently - informed my store owner that I'd no longer dink around with them. They were just too crazy-making for me!
Can you tell how I feel about these things?
Cheers,
David
Nice , there is actually a thread on this old unit...The mighty NuTONE 2561.
Don't replace these, Just keep them as wall art if nothing else.
As for me, I am still using mine, CONTINUOUS 24/7 operation for at least the last 10 years...I leave it powered up.
This model was was one the first high quality TRANSISTORIZED "Radio-intercom" models that could take 24/7 operation...It is a special unit as it could operate ELEVEN stations, Plus an outdoor music station, plus 3 door stations, plus the low voltage Nutone wall clock, and the Nutone door bell/chime system...This is a lot of operations for a single unit. For most part, top of the line.
One of the novel features of the 2561 is the ability to "Loop" wire it, or be standard satellite wired, or some combination of the two. This greatly aided installation flexibility, but...at the same time, made the loop wired units near impossible to retrofit. Which is why it should be left in place.
There are places that repair the master unit for around $200 (Space age electronics in Canton repaired one of mine) and this is the route to go.
http://www.spaceage-inc.com/nutonerepair.html
The 2561 had TWO input jacks, one in the wall cavity, and one external RCA (on the bottom front edge) which are great for an MP3 player or even better, your computer.
I used to hook my computer directly into the front of the unit with a stereo to mono adapter. This opens up all manner of crazy possibilities...Such as, holding a Skype conference call while being in some remote location, far from the computer microphone, using only the 5O year old hand controls and speaking/and listening directly from the ancient 45 ohm speaker cone.
You could walk from one end of the house to the other, hold a skype conversation the whole time, and never need headphones or carrying a hand phone. :thmbsp:
The real way to upgrade these (if you want 2 channel stereo) Is to buy a nice used companion unit. Which is what I did (I actually have 4 of these now, for parts). I wired up another unit, and use one for the main 11 station intercom, door answering functions, and RIGHT channel audio. Then the companion unit handles the LEFT channel functions to select rooms.
The sound is not audiophile, but it is high fidelity, and sounds surprisingly good...plus getting the companion unit was FAR cheaper than any retrofit (which would be north of $3000 for 11 stations, before labor).
So don't replace, appreciate...
Vintage USA engineering
I love my Nutone.
http://www.phacproducts.com/Nutone/NUTONE PARTS 2/parts/Intercom/2561,2562parts.pdf
very good tutorial on this model
http://tinyurl.com/mjcq74z
