got my c70 installed...this sounds pretty good!!
Discussion in 'Yamaha' started by gentlejax, Jun 14, 2018.
  1. gentlejax
    gentlejax AK Subscriber Subscriber
    1,010
    shreveport Louisiana
    I had forgotten what its like to get actual volume on a knob without running from dang near all the way 360 on the dial...sounds pretty good as it is. a little static when I mess with the parametric. not sure I like the parametric but I see where it make the bass/treble adjustment bigger.
    would a recap make this a better preamp or should i just deoxit the knobs?
  2. Blue Shadow
    21,951
    SE PA
    deoxit will do more than a recap at this point in time. It will clean up all the electrical paths and remove the scratchiness. Many report better sound quality with a good deoxit bath. Once you know the unit then you can consider a recap so you know what you got.
  3. avionic
    45,520
    Fort Dodge, Iowa
    The C-70 really makes the Denon DL-160 HOMC cart. sound fantastic.
  4. gentlejax
    1,010
    you recomend a deoxit bath? so I would what litterally spray it down and let it dry out? im running low on the ole deoxit..not enough for bath. guess I order more.
  5. avionic
    45,520
    Fort Dodge, Iowa
    Just the switches and controls electrical contact areas. Not the entire unit.
  6. Blue Shadow
    21,951
    SE PA
    Collect what runs off with q-tips and such and clean the RCA jacks with that.
  7. gentlejax
    1,010
    not literally a bath...okay lol
  8. avionic
    45,520
    Fort Dodge, Iowa
    OK...
