FINALLY. As much as i run the 400 anymore (80+hours a week) it was starting to take more and more gain on the volume control to get the kind of SPL I wanted, and the sound was kinda flat and lifeless, no depth, just Solid State!!!:thumbsdn:
Ordered a set of 7868's(EH's) from McShane on Monday. Came this morning with the mail.
Pulled the 400 out of the Coronet console, did an off going voltage check of the BIAS Circuit. (-19.20V) with the tubes pulling btwn 22-24ma each. Pins 1-7 was 370 and Pin 9 400.
Crammed in the new tubes after dripping De-Oxit on a pipe cleaner and running it in the sockets. I didn't think they'd go in, or they'd break before I got them in. MAN ARE THEY TIGHT!!! Think 13 year old virg....Forget it, there's no such thing anymore.
Powered on with meter attached. Everything came up nicely. Line voltage at wall 124, but with a -12V bucking transformer, I'm running 112 with 5.9V @ V7-8-9-10 heaters. After 30 minutes the tubes checked as follows: BIAS VOLTAGE IN -19.15V; PINS1-7 369V, Pin 9 399V. ma@ 10oHm resistor. V-13 24.35ma., V-14 27.21ma, V15 24.79ma, V16 25.43ma. This was with source set to AUX, and 50Wdummy loads onboard, volume @ ZERO. I haven't built or installed Drew's BIAS Mods yet, but it's definately on the list (going to top of list now). Tubes heated up evenly, no hotspots or redplating.
Put it back in the Cabinet after 1 hour test phase. Connected everything and powered up. OH MY GAWD!!!! Separation widened to across the room, there is a depth of field that wasn't there before (you can sense one section of orchestra behind another etc. feel like I'm back in High School Orchestra again.), I can hear finger plucking on strings now, sticks tapping on drum rims, or heads now, then the sound of the head or rim struck. Listeing to some Benny Goodman and can hear the clarinet keys clacking.....TOO FREAKIN MUCH!!! WOW!!!!!!!!
I've been listening to it for going on 7hours straight now. It's just getting better. The volume used to be set for 9:30-10:00 before and it was comfortable and sounded good. Now it's set like 08:00-08:30. All that from a set of NEW Output tubes. Between these and the 7591's in my Sansui 1000A, it's gonna be hard to listen to just one. (Flip a Coin???) Easier to eat only one LAY's.
The old ones are going in long term storage (backup's)
Larry
Larry
