Green Dot Diodes
Discussion in 'Exclusively Sansui' started by Rotoflex4, Jun 17, 2017.
  1. Rotoflex4
    Rotoflex4 Active Member
    100
    Good Morning!
    Does anyone know the recommended replacement for the green dot diodes found on various Sansui boards? (I'm currently looking at my AU-11000 F-2580 Driver Board). I've replaced the red dot ones before (using twinned pairs of 1N4148 diodes) but can't find much info on these green ones. The manual lists them as Sansui stock number 0340090, with simply "diode" as description. I'm hoping I can just use twin 4148's again, but I really have no idea. Any thoughts?
    I'm really happy with how the board is coming along btw. Nasty glue is gone....nice trim pots installed.
  2. AUD101
    AUD101 Parsley The Lion!
    592
    "The Big Smoke" - UK
    Are these D05 & D06? - if so the schematic shows them as SV-02 - and hence will need to search for replacements of these
  3. Rotoflex4
    100
    No....sorry....I should have been more specific. I'm looking at diodes D01-D04.
  4. AUD101
    592
    Hyperion likes this.
  5. Hyperion
    42,005
    Hertfordshire, UK
    AUD101 likes this.
  6. Rotoflex4
    100
    I recalled from previous threads that the red dot diodes are prone to failure. So....I presumed that the green dot ones were similarly weak. If you think they are reasonably durable, I'll likely just clean them up and put them back in (one of them did have a lot of Sansui glue on it).
    I do have about 40 of the 1N4148 diodes on the shelf, so it's an easy swap if need be.
  7. Rotoflex4
    100
    Thanks for that......now I feel like I'm getting on the right track.
  8. Rotoflex4
    100
