bajaed
My Rogue Cronus Magnum is working and it sounds incredible! Beautiful, deep sound stage.
I may have an interference/ground loop problem. When no music is playing, I'm hearing a mild to moderate hum or buzzing. The amp is in a shelf just under my TV and behind it is a power strip that the TV, BR,AVR and Rogue are all plugged into. There is also an amp right behind the Cronus that the cable company installed to boost my signal(would it be the main suspect?).
A couple feet to the left is a separate outlet that my turntable is plugged into. A couple feet to the right is an outlet the cordless phone is plugged into along with one of those small 2" desktop fans I was using to pull heat away from the amp.When i turned the fan off I heard a click through the speakers but the buzz remained.
Does this sound like a grounding issue or could it be a bad tube? Like I said, music sounds great just noticing the buzz when it's quiet.
I have a pro coming over this week to check my setup and get it dialed in. Could the buzz hurt anything in the meantime? Any ideas as to the culprit?
