Gunsmith in the house?
Discussion in 'Sports & Outdoor Adventure' started by whoaru99, May 7, 2017.
  1. whoaru99
    whoaru99 Epic Member
    40,947
    LoTL
    Whilst picking up after cleaning the following pistols I have the dreaded leftover mystery part.
    Ruger MkII
    1911A1
    Beretta 92F
    Colt Anaconda (is stainless so pretty sure it ain't from that).
    I've torn down the first three again but not seeing where/if this belongs. I know it was not on the bench before starting because I was working on a towel that I'd shaken out numerous times prior to starting.
    It is roughly 5/16" long by 1/8" diameter.
    Any ideas where it might belong?
  2. Lo-Fidelity
    Lo-Fidelity AK Subscriber Subscriber
    913
    Houston
    Barrel link pin on 1911? Not sure how you could get them back together without this pin?
    All of them cycle?
  3. whoaru99
    40,947
    LoTL
    Yeah, all of them seem to cycle/action fine.
    Barrel link pin is present and accounted for.
  4. silver faced
    silver faced Active Member
    442
    Arizona
    Looks like a recoil spring plug for the 1911A1
  5. lifer70
    lifer70 What? Subscriber
    738
    Boise, Idaho
  6. whoaru99
    40,947
    LoTL
    It's not #33/spring plug. The mystery part is way, way smaller than that. It's only 5/16" long and 1/8" diameter.
  7. silver faced
    442
    Arizona
    #12 maybe
  8. silver faced
    442
    Arizona
  9. whoaru99
    40,947
    LoTL
    Thanks for doing some looking, but I think not #11 either. I believe that would be hollow but the mystery part is a solid pin.
  10. silver faced
    442
    Arizona
    I would suggest in the future to do one gun at a time unless you have more then one work station. Myself i have different stack-able trays . so i can never mix parts. I do all my own loading also . Take it slow an steady. Aim small miss small
    Oerets likes this.
  11. whoaru99
    40,947
    LoTL
    I did disassemble only one at a time, but didn't notice the mystery piece until I was rearranging to start on the rifles. As well, I know that I did not intentionally remove that part. It had to have fallen out of something when I set it to the side to work on another part of the same pistol.
    What seems odd is that they're all back together and seem to cycle fine. I don't like the idea of having to run live ammo through all nine guns again just after cleaning them...but I suppose at some point the function has to be checked in a live fire manner. :dunno:
    Next time though I will for sure be using a towel that doesn't have a pattern with dark spots and moderately deep pile on it.
  12. John James
    John James "Bob's your uncle" (Stolen) Subscriber
    8,159
    Piney Flats, Tn.
    Just my opinion, but I wouldn't live fire any of them until I found out where that pin came from. The manufacturer didn't put in in there for laughs.
    datafone likes this.
  13. Hyfi
    Hyfi Addicted Member
    5,457
    Bucks County, PA
    Where is your manuals and exploded view of all the parts? I would check into that if still a mystery, and no way would I start firing with unknown missing parts.
    I always do one gun at a time as suggested earlier for similar reasons.
  14. whoaru99
    40,947
    LoTL
    I don't disagree, but I've been through the parts diagrams several times and have since disassembled/reassembled them twice more now with no indication where that came from/where it goes. Can only repeat the same action so many times getting the same result before you have to move on to something else/next step.
    As far as the manufacturer putting it there, yeah, I get that. However, by the same token there has to be a place for it to go and all spaces seem properly occupied.
    I've had all these for years and have disassembled all of them numerous times to this same level (basically field strip, not total disassembly) with no recollection of a part like that needing to be placed back.
    Hell, at this point I'm not even sure it came from any of the guns. That's just my assumption since I don't have any better explanation why it came to be where it was. It's a real headscratcher!
    (As previously mentioned, while I did do multiple in succession, there was never more than one disassembled/reassembled at any given time).
  15. soundmotor
    soundmotor super modified Subscriber
    Is it 2 pieces? The color makes it look like a blued part fitting into an unblued part.
    I don't see any wear on it. Any of the pins that would come out might have some bearing wear even slight. Granted I don't have any of the same handguns but I can't think of any with a part like that.
  16. whoaru99
    40,947
    LoTL
    It's just one piece. Black, almost like a coating on each end, not really like blued per se. There are a couple real small spots on it, but to your point nothing that really looks like bearing/pivot point wear.
    I might have to break down and bring it by a couple shops for their opinion. Unfortunately none right in town so it'll have to be a one-of-these-Saturdays road trip.
  17. stonedeaf
    stonedeaf AK Subscriber Subscriber
    883
    Couldn't be a firing pin or transfer bar ?
  18. whoaru99
    40,947
    LoTL
    No parts seem to be missing as best I can tell. :wtf: :crazy:
  19. usedto
    usedto Lunatic Member
    16,522
    Central Moonbeamia
    Not knowing what any of the springs in your guns look like, could it be something someone put in behind a spring to shim it up?
  20. whoaru99
    40,947
    LoTL
    Don't see any place it might belong.
