HalfApt
Well-Known Member
re: the H/K Rabco ST-7 tracking roller issue - it's been covered in numerous older threads, but thought it better to start a new one.
I think I've found the ideal replacement: "Square-section O-rings", aka "square-rings"
Briefly, my ST-7 roller tire died the gooey death many moons ago. I knew about square rings back then, but nobody had the right size as normal stock, and having one custom made was too expensive, so I went with the diy alternatives.
Was never satisfied with the standard O-ring (inconsistent between pressings), so made a latex tire using double-thickness of 1/16" wall latex tubing. This worked better than the O-ring. Still had minor issues, but I could live with it for the few times I played vinyl.
A recent urge to find a better fix found a vendor with the right size "square-rings", so I bought them & got one installed. The ST-7 tracks straight and true now!
These are 3/8" ID, 5/8" OD, 1/8" section. A little tough to stretch over the wheel rim, but fit snug once pressed in, and run true.
Buna-N normally comes in 40, 70 and 90 durometer hardness. Would have preferred 40 (softest), but they only had 70 & 90 in the square-ring, and the 70 is working fine so far.
Vendor: The O-Ring Store
