Hammarlund HQ-145X
Discussion in 'Tuners' started by bre's dad, May 19, 2018.
  1. bre's dad
    bre's dad I drank what?!?
    1,652
    indiana
    Not a stereo tuner, but still a tuner (shortwave general coverage). I'm needing someone to do an alignment on it. Can anyone recommend someone? Prefer not to ship as it's large & heavy. I'm in south central Indiana.
    Martin.M likes this.
  2. gadget73
    37,814
    Southern NJ
    Maybe check the antique radio forums or videokarma. This one should be pretty simple to align since its just AM. Don't need fancy gear for this, just a reasonably stable and accurate sig gen will get it done handily.
  3. Joe Roberts
    Joe Roberts Agent Provocateur Subscriber
    1,162
    DC
    You could probably touch up the alignment it with the crystal calibrator signal, if you have the plug-in crystal calibrator.
    What makes you think it needs to be aligned? These radios usually wouldn't drift too far off unless someone was messing with it.
    If sensitivity is way low, I would look at capacitors, then tubes, in that order.
  4. Martin.M
    Martin.M Collecting Tek
    156
    germany
    Double conversion super, 5 selectable bandwiths in the second IF, BFO.
    required is OM with heart for BA. A sweeper test place, tubes tester, some other gears. And a lot of fun, this is one of the very better radios.
    greetings
    Martin
    Pio1980 likes this.
