It may be common knowledge for other members, but I was relieved to find that the connectors below are still an available item:
Seen in another thread, the BA5000 that I am working on had been clipped of almost all of its connectors, both the multi circuit Molex connectors and these single housings for the headers with the .093" round pins.
From what I have read, it is not uncommon for connectors to have been removed from many owner's gear and wires soldered directly to header pins.
My parts unit had several remaining, but with no identification on the housings other than "AMP" and a number that varied from housing to housing I didn't have much to go on. Digging around, I located the current AMP (TE Connectivity) part that I am pretty sure is the correct item original to many Sansui products.
These came from Mouser, who had the housings but not the terminals, and I am still working up an order for Digi-Key to get the corresponding crimp terminal. Digi-Key does not have the housings.
The part number is: 171156-1.
The (I believe correct) crimp terminal part number is: 170073-5
As I said, others may be aware of these, but I was certainly happy to find an original part that is available some 40 years down the line...
