onanysunday
Listen carefully
Hello everyone. Just looking for a little help buttoning up a restoration. I've mostly recapped this gem with green ERO MKT1822 and red Audyn Q4 caps. Sounds much better than it had before. However, I'm at the final stage tackling those 3 large multi-section capacitor cans on top. I've increased capacitance and voltage as per prior AK recommendation and ordered suitable replacements that are somewhat "mocked" in place (see notepad photo) They are C23, C24, and C25. C23 is soldered in place and DONE. I need help determining if I should just twist the negative leads of the new caps together with the the black wire(s) for C24, C25 and what the yellow line is for which connects these caps to tubes that I don't see listed in the schematic? Where do the yellow leads need to be re-attached after I have disconnected them from the underside of the original, multi-section caps?
I'm also looking to replace those unusual, heavily oxidized and worn RCA input jacks. Ideas?
Still getting a 60Hz hum which may be remedied after completing the full recap. But..the hum is interesting in that it diminishes about 5-10% when I touch the chassis. And, interestingly, my hum actually goes away intermittently on both channels and then comes back very faintly on its own while listening to music. I think there was once a suggestion somewhere about splitting the bus bar into two parts to make it quieter? Any help with the C24 or C25 multi-section caps or hum is appreciated. Thank you.
* Here is a link to a larger, more legible schematic that was saved mislabeled. https://manuals.harman.com/HK/Service Manual/A500 schematic.pdf
