Started my refurb on this unit last night. I DBT'ed it, filled the empty tube sockets & fired it up. As received, it does play but has bad hum and the tuner is definitely wonky - stereo light comes on only when stations are mistuned to give loud noise. I did a basic chassis & faceplate cleaning, cleaned the posts, switches, and tube sockets, and started on the power supply caps. That's where it got interesting.
On the schematic I have (attached), R110 is 3900 ohms. On the actual unit, the original looking resistor is marked and measures 39K ohms. 3900 is more in line with what the other sections of this can cap use (they have 4700 ohm resistors, which match the schematic. Any thoughts on which is right? Anyone else have on of these they could look at?
I also found that R107 (1500 ohm resistor) was burned completely up, so I will probably replace with a higher wattage rating - 1 or 2 watts instead of 1/2 watt. Any risk there?
Thanks!
Thanks!
