HDMI Output to RCA (analog audio).
Discussion in 'Home Theater & Video' started by 62caddy, May 14, 2018.
  1. 62caddy
    9,687
    NEPA
    A relative recently got a Sony UPB-X800 DVD player but it only has HDMI outputs. What would be needed to get an analog signal to feed a receiver so he can use his speakers.
    Would simple adapter cables work or is some sort of D/A converter needed?
    I'm not very knowledgeable about HT equipment - any help would be appreciated. Thanks.
  2. awillia6
    awillia6 Super Member
    1,383
    That player has a coax digital out. Does your relative's receiver have a coax digital input? Most AVRs and non-vintage receivers have such connections even if they are too old to support HDMI (audio/)video. Suggest you find out the receiver model and look up its capabilities before deciding what to do. Also what is the PURPOSE of connecting the receiver? Surround sound, stereo CD playing, what?
  3. whoaru99
    whoaru99 Epic Member
    40,917
    LoTL
    Yeah, as awillia6 eludes to, knowing the make/model of receiver of topic goes a long way to making a good recommendation.
  4. EngineerNate
    3,458
  5. awillia6
    1,383
    I'm not running away from anything...never do.
  6. Grenadeslio
    Grenadeslio Super Member
    3,247
    GSS61 likes this.
  7. 62caddy
    9,687
    NEPA
    Receiver is an Onkyo TX-SV636; Speakers are a pair of Dynaudio S 1.4 on stands.
    The receiver and speakers were purchased at the same time sometime in the 1990s.
  8. whoaru99
    40,917
    LoTL
    Thanks for the grammar policing.
    Alludes to.
    Although, in a way, a concise way to clearly state request for make and model did elude you. ;)
  9. awillia6
    1,383
    At least now you can quit worrying about embarrassing yourself with a hot date or prospective employer with a similar penchant for pedantry...
  10. whoaru99
    40,917
    LoTL
    Grammar policing on a forum is never really about the grammar.
  11. whoaru99
    40,917
    LoTL
    Since that receiver appears to have no digital inputs, I agree with Grenadeslio's recommendation. That unit is the one I normally recommend too. Be advised there is a very similar model that does not have 5.1/multichannel decoding capability. Spend the few extra bucks to get the one with 5.1/multichannel capability. Makes less problematic setup as it will work with either bitstream or PCM output setting.
    stish, awillia6 and GSS61 like this.
  12. GSS61
    GSS61 Super Member
    1,624
    Tallahassee
    Looks like that unit does not have a digital input... stereo analog RCA inputs only
    You need an "HDMI Audio Extractor"... a basic 2.0 output unit runs about $20 on Amazon https://www.amazon.com/Musou-Extrac...rd_wg=VUR3B&psc=1&refRID=6ZN1BZ0DEG24JMBX8EYR
    This lets you run the HDMI signal to the HDMI input of a HDTV while sending L/R analog audio output to a stereo system
    botrytis likes this.
  13. 62caddy
    9,687
    NEPA
    Thanks for the recommendations.
    One more question - which output should be used and what IC is needed? Is there any advantage or disadvantage of using either (aside of cost)?
    I assume we use the output "audio only". Need the cable that connects that to the DAC.
  14. botrytis
    29,402
    PODUNC USA......
    DO NOT USE COAX OR OPTICAL as they are synchronous meaning they get out of sync fast and smear sounds.
    I would get an HDMI breakout box which has a pass through for HDMI and can take off the audio to RCA - GSS61 beat me to it.
  15. awillia6
    1,383
    It is with me. Stops the cringing which makes my neck hurt.
  16. awillia6
    1,383
    Could you explain further, please? I have optical out going from my 4K TV to my AVR's optical in; seems to work fine for all sources. Is there some sync that happens in the TV that wouldn't in the 4K BD player?
  17. 62caddy
    9,687
    NEPA
    Can anyone recommend the cable that goes between this-
    And this
    Thanks!
  18. whoaru99
    40,917
    LoTL
    A composite video cable having RCA plugs would be fine or a cable with RCA plugs pulled from a component video bundle.
    For that matter, practically any RCA-type cable will work over a short distance but I suggest one having coaxial-type construction rather than twisted pair-type construction.
    From the orange jack on the player to the yellow jack on the DAC/decoder.
    stish likes this.
  19. whoaru99
    40,917
    LoTL
    Typically the issue is not optical/coaxial digital so much as it is the video processing in the display.
    I think even if you extract the audio by HDMI extractor there is similar risk of having lip sync problem.The display still processes the video signal and that's where the video delay relative to the audio is normally introduced.
  20. whoaru99
    40,917
    LoTL
    @62caddy
    Brakes on for a moment...
    Is the DVD player feeding a display/TV?
    If so, does the TV have analog outputs?
    awillia6 likes this.
