Heathkit AA-100 phono stage acting weird... - SOLVED -
Hi,
I've finally completely redone the AA-100 my father kindly donated to me 4 years ago (it was at this time my first tube amp). All resistors, caps, selenium and electrolytics replaced. Resistors matched within 1% on each side.
I installed a lot of wire jumpers on the PCB's as a lot of traces were damaged.
However, it exhibits the same behavior as already discovered back two years ago (after a first visit to a tube tech, back then I was a tube noobie and afraid to do the repairs myself):
- When I plug the "R" lead of a TT in the "R" input and the "L" lead in the "L" input (as it should normally go BTW), the left side is louder and has more bass. The right side is notably weaker and has more treble... The ground of the TT is attached to a screw underneath the amp.
- When I plug in reverse, meaning "R" of TT in "L" of the AA-100 and "L" of TT in "R" of amp: all is fine, equal volume and tone on each channel...!!! All of this behavior verified with mono pressings of The Beatles.
As you could doubt, this situation puzzles me. Why reversing the connections could cause something like that?
It was verified with two different working turntables so the source is out of the equation (the actual Garrard type A and a previous Aurex TT).
I swapped the EF86's and 12AX7's of the phono/tape head stage without any change.
I also swapped all remaining tubes without any change (7591's and the the two 12AX7's in the tone stage).
BTW, the amp is now fine sounding with a quad of EH7591A's biased at around 32-34ma, verified by adding 10 ohms 1/4w resistors to each output tubes cathodes.
So, could someone explain to me what's going on there? Something related to ground? I know it's hard to circumvent without access to my amp but maybe you could point me in the right direction.
It's not as I can't use the phono right now as I've found the reverse connections workaround but I want to understand if possible.
Thanks.
Patrice
Hi,
Thanks.
Patrice
