Good morning,
I'm an original owner of two of these monsters and still have the original manuals to boot. Additionally, I've had the pleasure of trading a few emails with a retired Heathkit Engineer regarding the AA-1800 some years ago.
First off. Yes, the AA-1800 does consist of two descrete amplifiers but only has one common power supply. The second cord is the "on/off" switch as this is plugged into a switched outlet.
The AA-1800 was conservatively rated at 250W due to FTC restrictions on kits. In reality, it's closer to 350W per channel at 8 ohms.
Issues with the amp are few but extreme. Do NOT, for any reason, ever connect or disconnect an interconnect wire with the amp turned on. This sucker can easily fry a power meter or a voice coil. (experience speaking). An extended overload caused by someone pulling off an interconnect can (will) cause a cascade failure of every TO3 transistor in the channel. (Done that to.)
R. Crain
