kaplang
Works for me !
Trying to get a Heathkit AA151 back to operational. It has no output at all.. When it is powered on all the tubes light but after a few seconds of being turned on the GZ34 rectifier tube arcs and the amp meter I have in line with the power cord and variac shows greater then a 2 amp draw. This only happens for a for a split second and then it settles down to a 1 amp draw and then it starts all over again. Rectifier tub arcs and then greater then a 2 amp draw. I have tested the tube and it tests good. I also had another tube to try and it shows the same problem. I don't think my problem is the tube. I need some direction at where to start looking.
Any help here will be greatly appreciated.
George
George
