hotgas
Super Member
I've had this integrated tube amp for a while now but just started to play with it recently. This is a very sweet amp and I can listen to it for hours without listening fatigue if it is working right. Here are the problems.
When I turn it on the left channel is slow to respond. Wait for few munites and play with the balance knob I got the left channel to play. The right channel is always good.
Then I turn the amp off, connect another speaker to the center speaker connections of the amp, turn it on, and the left channel is off again.
So I remove the center channel and only use the left and right ones, but now no matter how much I adjust the balance knob I can't get the left channel to work. Questions:
1) Could the balance knob be the culprit?
2) Do I miss anything? In the back I can see couple wires with hooks which are supposed to tie to something but I am not sure where.
3) Or anything else?
