Help for a newbie to DACs
Discussion in 'Digital Sources' started by Madman1, Oct 12, 2018.
  1. Madman1
    Madman1 AK Subscriber Subscriber
    144
    Winston Ga
    Ok, so forgive my ignorance but I have mostly listened to vinyl and occasionally my iPhone directly into aux inputs of vintage tube amps for years. I recently got a Maverick D2 from a fellow aker and need to find the simplest way to bypass the iPhone internal Dac. I understand that streaming from Apple Music is blasphemy but, that’s what I have easy access to and just prefer that for simplicity for now. Is there a plug,cord,dock etc... that will accomplish this?
    Thanks.
  2. louisjames
    louisjames The "real" Louis James Subscriber
    2,056
  3. Madman1
    144
    Winston Ga
    Thanks Louis, actually I have both a iPhone 8 and a iPhone 5 that I can use. I bought a chromecast audio not knowing that I couldn’t stream Apple Music through it.... I’m purchasing a Apple AirPort Express this week and hope that might be my solution but, the camera adapter maybe the simple connector I asked for. Thanks again.
  4. GChief
    GChief Not well known, super member or other silliness Subscriber
    2,544
    Eastern NC
    I would still hook up that CCA. You can try the free versions of the different streaming services. Worst case is you get to surf a lot of music you would not hear otherwise for the cost of your time.
    Edit: you can run those services via thier apps on your iPhone.
  5. Madman1
    144
    Winston Ga
    Yea I think I’ll hold on to the cca for now and play around with it a bit.
    GChief likes this.
  6. GChief
    2,544
    Eastern NC
    You can 3.5mm >>> RCA or 3.5mm optical if you do pick up a DAC. I have all the stuff I “want” that I don’t have ripped to my iTunes or on vinyl saved on Tidal and Spotify accounts. It’s a great tool for finding new music!!
  7. Madman1
    144
    Winston Ga
    Great, thanks for your help.
    GChief likes this.
  8. Yamaki
    4,351
    Hillsboro, Oregon
    Ever thought about implementing a full digital system with a stand alone DAC, a music server and some software to manage it all? Just curious.
    OnTheBlitz likes this.
  9. GChief
    2,544
    Eastern NC
    What’s the fun in that ;) :D
  10. Yamaki
    4,351
    Hillsboro, Oregon
    hahahaha....
    There are new worlds to explore and conquer in the digital world.
    GChief likes this.
  11. GChief
    2,544
    Eastern NC
    If the ritual of spinning LP’s was not my therapist I would be all over it.
    :beerchug:
  12. Madman1
    144
    Winston Ga
    Everything you just said make my brain hurt. Yea I’m almost completely vinyl. I have already purchased a maverick d2 tube magic dac. Just trying to get me feet wet not jump in the deep in.
    GChief likes this.
  13. Yamaki
    4,351
    Hillsboro, Oregon
    I understand. It made my head hurt at first as well. But, with some help here on AK and a local audio buddy, it happened. And I am very, very glad it did.
    Good luck!
  14. HiFiAnon
    HiFiAnon New Member
    18
    @Madman1, I'm also completely new to this, so I'm just writing what I think is the answer.
    Your D2 has optical in. The Airport Express has optical out.
    You can stream to the AE, it feeds your D2 with relatively clean signal, then the D2 does the magic and feeds your amp.
    This bypasses the DAC of your phone and the one in the AE.
  15. Madman1
    144
    Winston Ga
    That’s exactly the direction I’m headed. Should have both the airport and the cable by Wednesday. I’ll post how it works out. I’m running a pioneer elite dvd with SACD thru it right now and it’s just ok.
    GChief and HiFiAnon like this.
  16. GChief
    2,544
    Eastern NC
    That’s good to know, I think my DV-45 sounds a little better as a transport thru my SMSL -M8a.
