xbart
Super Member
I'm trying to find out how much gain this preamp has using the LOMC input.
I have a LOMC that has 0.2mV output and read the optimum gain is 64 db.
The preamp in question is a Luxman C-02
Here are the specs I found for the Luxman C-02
Pre output : 1V / 220 Ohm {100 Ohm}
Maximum pre output : 18V
Rec output : 130mV / 220 Ohm
Maximum rec output : 18V
THD : 0,005% (line, 2V output)
Frequency response : 5Hz...100Khz (± 0,5dB, line level) {± 0,3dB}
20Hz...20Khz (± 0,3dB, phono)
S/N ratio : 75dB (MC, IHF-A, 250µV) {77dB}
85dB (MM, IHF-A, 5mV) {90dB}
110dB (line, IHF-A, 1V)
Inputs : 100µV / 47kOhm / 100 Ohm / 300 Ohm (MC)
2,0mV / 50kOhm (MM)
130mV / 47kOhm (line)
Max. phono level : 12mV (MC) {15VmV}
250mV (MM) {280mV}
Bass turnovers : 200Hz or 400Hz (± 8dB)
Treble turnovers : 2Khz or 4Khz (± 8dB)
Low boost : +8dB at 100Hz
Subsonic filter : 30Hz (6dB/octave)
2,0mV / 50kOhm (MM)
250mV (MM) {280mV}
