Help identifying and sourcing Sony TC399 VU Meter bulbs.
Discussion in 'Tape' started by Mark1892, Apr 16, 2018.
  1. Mark1892
    Mark1892 New Member
    16
    Hi, a friend has asked if I could have a look at his Sony TC399 as one of the VU Meters wasn't illuminated. Once stripped down it was apparent the bulb has been removed. Manual states 6v 35ma bulb which when looking at the one in the other meter, it is a push in fuse link type. I am struggling to find a replacement online, can anyone help? [​IMG]
  2. Mark1892
    Mark1892 New Member
    16
  3. dhnash
    dhnash Well-Known Member
    587
    Wildwood, MO
  4. Mark1892
    Mark1892 New Member
    16
    Thanks dhnash. Not being mine I'd prefer to keep it original and not solder lamps in but looks like it might be mine and his only option. Found these on UK Ebay, still be suitable? I'll have to replace the one working lamp aswell to keep the light levels the same too. Screenshot_20180417-102345.png
  5. dhnash
    587
    Wildwood, MO
    The ones you found appear to be very similar the ones I suggested (same electrical specifications and only a 1mm difference in length) so I believe they should work for you.
    Mark1892 likes this.
  6. Mark1892
    Mark1892 New Member
    16
    Thanks I'll get 2 ordered.
  7. Mark1892
    Mark1892 New Member
    16
    Just found these, what difference would I experience using something with a 0.25a rating instead of 0.05a? A no go or acceptable? Screenshot_20180420-144354.png
  8. dhnash
    587
    Wildwood, MO
    There are at least two possible issues with using 0.25A versus 0.05A lamps:
    1. The significantly higher current draw may be more than the transformer can safely supply.
    2. The heat generated by the higher wattage lamps may be so much that it could could damage the plastic parts of the VU meters.
  9. Mark1892
    Mark1892 New Member
    16
    Perfectly answered, I'll stick with your original suggestion. Many thanks
  10. Mark1892
    Mark1892 New Member
    16
    All sorted. Just replaced the right hand side vu bulb with the one above from ebay and it's not too different from the original in the left. Cheers dhnash. 20180429_191309.jpg
  11. dhnash
    587
    Wildwood, MO
    Glad to hear that things worked out well!
