The kit
I have a pair of Jamo Studio 105 speakers connected to my Sansui AU-607 Integrated Amplifier.
Jamo Studio 105
Frequency range : 60Hz-20,000Hz
Impedance : 4-8ohm
Short Term Power : 105W
Long Term Power : 50W
MADE IN DENMARK
Three woofers:
One 5cm, one 9cm and one 17cm
Sansui AU-607 (released 1976 yep that is old)
2 channel amplifier with 4 speaker wire ports
65W + 65W (65W per channel)
"When using 2 sets of speakers, please make sure that each pair does not exceed 8ohms"
20Hz-20Khz, 8ohms.
The problem
The speakers do have an impressive large 17cm cone however the speakers really lack bass. When I move my ear right up to the 17cm cone, I can hear that there is quite a lot of mid-high noises coming from there.
Now, I have a Panasonic HiFi with some speakers. The speakers have 2 separate pairs of wires, one for the treble and one for the bass. When I remove the treble, all I can hear is the "bwaa bwaa" of the bass.
So, how come this is not the same with the 17cm cone on the Jamo Studio 105s?
Example
Pop music on the HiFi with the treble unconnected = "bwaa bwaa" no chance of hearing lyrics
The same on the Jamos, going right up close to the 17cm cone, I can hear the tune and everything when I just want the lower end of the sound spectrum going there.
My guesses
Is there some underpowering problem with my amplifier? Or, is it just a simple matter that I have some bad speakers that are badly connected?
I'm guessing in the HiFi, the low noises are being directed to the bigger cone and the high noises to the small cone. This is being done in the HiFi box.
:scratch2:
From what I understand, my speakers lack a different set of wires for each cone and so I am just getting a mixed bonanza of sound through each cone?
Side note
I have a set of 3.1 3.5mm jack speakers (satelite + subwoofer) and those output a load more oomph of bass even though the subwoofer's speaker is tiny! Maybe something like 6cm!
I hope that you guys can help!
Jamo Studio 105
Impedance : 4-8ohm
MADE IN DENMARK
Three woofers:
20Hz-20Khz, 8ohms.
The problem
Example
My guesses
:scratch2:
Side note
