The Realistic TM-1001 tuner is supposed to have built in AM (the bar) and FM (the power cord as seen in the picture?) antennas, but I live in a small valley which has proven to reduce signals in some areas of the house.
I bought a powered FM/AM antenna in an attempt to improve reception, but now I don't know how to hook it up. The AM connection consists of 2 wires, but as you can see below there is only one AM antenna terminal. Secondly, the FM portion is coaxial style but comes with a 75 ohm to 75 ohm (not 75 to 300 ohm) converter that also converts it to 2 wires. However, I have no idea what the 75 ohm terminal on the back of this is designed for. It is the terminal on the right that consists of a metal loop with a screw below it. There are two 300 ohm terminals, but I assume this isn't the correct spot to connect since the converter is 75 to 75 ohms.
Any advice is appreciated!
